Mach Discussion => General Mach Discussion => Topic started by: kencor1 on July 20, 2010, 03:12:25 PM
I am trying to setup the Inhibit functionality in Mach. I have input 1 set to pin 15 of the bob, I have checked the General Config box to Enable the Function, the input 1 led will toggle on and off but the Inhibit led and functionality will not work. I am trying the use the inhibit function so that my programs will not begin to run unless my charge pump is active. Can anyone point me in the right direction on this? I have checked the manual but I can't seem to find anything on this that will help.
Tom
Should be straightforward thing to do, just the signal to your BOB, Input 1 set to the correct pin and port and the option enabled in General Config.
What version of Mach are you using and if you attach your xml I will test it here. I have just simulated it with a generic xml and it seems to work fine when I emulate Input 1.
Thanks, Hood I was able to get it working. the only thing is that the led does not light but it is working.
Tom
Good to hear :)
