Third party software and hardware support forums. => Third party software and hardware support forums. => Topic started by: Sam on July 18, 2010, 07:13:36 PM
Well, I think I'm about ready to purchase a spindle motor for the mill in progress, however, I'm about as dumb as a box of rocks when it comes to choosing a motor. I'm thinking a VFD with a good 3 phase motor would be great, but I really don't know enough to make an educated decision. I've seen that I can get a new 3hp Baldor or Leeson motor for about +/- $200 delivered. I've dug up some specs on some motors, but I really don't know what I'm looking at.
http://baldor.com/products/detail.asp?1=1&catalog=VM3561&product=AC+Motors&family=General+Purpose|vw_ACMotors_GeneralPurpose&winding=35WGY334&rating=40CMB-CONT (http://baldor.com/products/detail.asp?1=1&catalog=VM3561&product=AC+Motors&family=General+Purpose|vw_ACMotors_GeneralPurpose&winding=35WGY334&rating=40CMB-CONT)
https://www.surpluscenter.com/item.asp?item=10-2526&catname=electric (https://www.surpluscenter.com/item.asp?item=10-2526&catname=electric)
2 or 4 pole? Pro's and con's? I would like to have more power at slower speeds, rather than higher, so I guess a 4 pole is more desirable?
What about VFD options to look for? Needed inputs/outputs for features that might be useful, relays, braking features, fieldbus options, etc.... I have a small bit of experience with the Danfoss drives, and I know they are quality drives, plus and I have a local supplier, so I'm kinda leaning toward those.
http://www.danfoss.com/BusinessAreas/DrivesSolutions/Products/Frequency+Converters.htm (http://www.danfoss.com/BusinessAreas/DrivesSolutions/Products/Frequency+Converters.htm)
I know I'm asking allot, but any help at all is appreciated. Thanks!
The 4 pole torque is optimum at the base speed, so with a standard motor you can go up to 120hz.
If you are buying new you could spend a bit more and look at the vector rated motors, these generally take you up higher in the rpm max range.
Also suppliers like WEG have motor/VFD combinations that offer 100% torque down to zero rpm with no cooling fan.
A nice features to have on a spindle is up-to-speed, which would need an input into Mach, not sure if it has the option written in.
This way machining motion is delayed until the spindle is up to speed.
Nosmo.
