Mach Discussion => General Mach Discussion => Topic started by: josesabaris on July 05, 2010, 05:10:17 PM
I apologize but I do not write very good English, I am using plasma MACH3
and thc 300, I have a problem in circles, when thc does not disable the delay in drilling, is that there is a macro to turn off the thc, but this way there is no delay in the cut, anyone can write a macro to clear the thc-up entries
and thc down?, (and another to activate, of course.
Thanks for the help.
Sorry I don't quite get what you mean by
" when thc does not disable the delay in drilling" All the THC does is move the z up or down based on tip voltage compared to set voltage
When cutting circles turn off the thc, but thc off with no signal detected arc ok,
and I can not implement pierce delay.
The entries disable thc thc up and down, so does the arc ok.
it would also be a script that will disable thc down under acceleration, deceleration and circles, the feedrate is always lower in Cirules that f g code, something like
if feedrate < f (gcode) -100 Then disable thc down
That type of operation would have to be done through a plugin to mach.
sounds like you need to use anti-dive.
