Mach Discussion => General Mach Discussion => Topic started by: shawn_clmachine on October 16, 2006, 11:21:53 AM
Title: Automatic Oiler
Post by: shawn_clmachine on October 16, 2006, 11:21:53 AM
What is the best way to implement an automatic oiling function. It. would be better for it to happen after a certain amount of motion rather than time. I saw a post about using the macropump to do this. Can someone elaborate on this please?
Shawn
Title: Re: Automatic Oiler
Post by: Graham Waterworth on October 16, 2006, 11:27:43 AM
Why not drive one off the leadscrew with a belt that way it will only lube when its moving.
Graham.
Post by: shawn_clmachine on October 16, 2006, 07:04:38 PM
My machine already has an automatic oiling system plumbed and powered, it just needs to have a relay triggered to initiate an oiling. One of the outputs from Mach3 could be used to do this, if I had a way to tell it when.
Shawn
Post by: JDolecki on October 16, 2006, 07:35:30 PM
On many machines the lube system is tied into the motor, when the motor is running the the lube system is functioning. Assuming you have some king of contactor for the motor you can take off that if its 220 or 3 phase. or if its a 100 motor just parallel it to the motor. so when the spindle is running or the machine is in motion the pump system is getting a signal. then put the pump on a timer to run a few seconds every several minute. you really just Have to watch it a tune the system so you getting adequate lubrication but it just isn't running all over the floor.
Post by: Chaoticone on October 16, 2006, 08:13:36 PM
One tip Shawn,
   Be sure to check your metering valves. I'm new to Mach but not machines. It is always a good idea to make sure your getting oil where you want it, not just leaving the pump. All of ours are as you say, on a timer. I wish I knew how to help you set that up. Your idea is much better. ;)
