Mach Discussion => VB and the development of wizards => Topic started by: budman68 on June 14, 2010, 02:30:37 PM
Hi all,
Yes, it's another dumb simple VB question from me.
I would like a button on my screen to Zero the X + Y DRO's together with one press.
I know I can use the OEM codes 1008 (X) and 1009 (Y), but how do I make a VB script to do this?
Thank you kindly-
You could use this code as your button script
SetOEMDRO (800,0)
SetOEMDRO (801,0)
Greg
Worked perfectly Greg, thank you very much.
Now I realized you're using the OEM codes for the DROs, but how did you know how to put the comma and add the zero's to actually zero the DRO? Is it just from fooling around with VB, or do you actually know VB scripting/code?
Again, thank you- :)
The little I know of this stuff is just by looking at other examples and fooling around with it. :)
Greg
Ah, I guess that's how I'll be "learning" as well, lol!
There's useful info for things like this in the WIKI including a Cypress VB manual such as it is.. There is I believe a newer version of the (Mach specific) VB reference written by (I think) HimyKabibble but I'm not sure where it is. Maybe a sticky at the top of this topic would be an idea?
Ian
