Mach Discussion => General Mach Discussion => Topic started by: dpekin on June 02, 2010, 10:57:04 PM
Title: Upgrade from R1.84 to current rev advisable???
Post by: dpekin on June 02, 2010, 10:57:04 PM
Hello,
I'm currently running version R1.84 on a 1GHz computer w/ 512 MB of RAM.  It runs somewhat but has problems with a  "limit switch triggered" error when I'm running a g-code program.   I don't even have limit switches on the system so I assume this is a problem with stepper pulses counting properly or ???  It is connected to a DSLS 3000 MicroMill system.
I have a few questions:
Should I try to upgrading to the current rev to see if this help the limit switch problem or is there a solution w/ 1.84?
If I upgrade will my current license be good for the new version?
Will the machine config XML from R1.84 be OK for the new version?   (I'm sure I woudl have a problem bringing up a system from scratch since I have just purchased this used system).
Any thoughts appreciated.
- Dave
