Mach Discussion => General Mach Discussion => Topic started by: lucky021 on May 10, 2010, 02:39:10 PM
Hello, I met a problem here
when I use button jog mode with 100% jog rate, the motors are running much faster than I input "G1 X20 Y20 Z20", why and where I can setup it?
thanks for any help
When U use G1 that means linear interpolation @ last feed or current feed rate the jog feed doesn't effect the Gcode feeds
