Mach Discussion => General Mach Discussion => Topic started by: fabiototo on April 26, 2010, 04:20:44 PM
good morning,
in old version if mach 3 , it is possible to change coordinate x,y,z axis in the windows (Alt-1).I remember, i click on the label where i have my coordonate and i change the value .
But in the Version R3.042.038 it is not possible .Why or perhaps i make a mistake ?
Thank you for your help
fabrice
escuse me for my bad english
I think you may be viewing machine coords as it is still possible to change offset coords in the DROs by typing the number and pressing enter on the keyboard. If however you are viewing machine coords you will not see the numbers changing until you go back to offset coords.
Thank you for your answer.
I have tried with a normal compuetr and i see when i make the change with numerical keyboard , tre is no problem.
But when i tried with number up to azerty whit shift , i can't change this.
My problem is, i use a computer portable for milling and i haven't numerical keyboad, i have only the number up azerty.
Have you got a solution ?
Thank you
Fabrice
excuse me
i have find the solution
with the portable iblock the touch fonction:
fn + F11 and after i can use the number with touch ,jkluio789
I don't know if i have very clear.
Thank you
Fabrice
