Mach Discussion => Mach Screens => Flash Screens => Topic started by: elpablito on April 25, 2010, 02:42:35 PM
Im doing some modifications to my screenset in order to share it with the community.
For anyone to be able to use it, I need to remove behaviors that are specific to my configuration.
One of them is tool change.
I dont like to keep my tool information inside mach, because I have my tool library in my CAM.
When I generate gcode, the tool information is included this way:
(TDESC;ID:14;DESC:1/4" End Mill Straight;TYPE:END_MILL;TOTLEN:80mm;OHL:50mm;SL:30mm;CL:20mm;SD:15mm;TD:6.35mm;CR:0mm;AN:0mm;FLUTES:2;MSG:In drawer 3)M810
M6 T1
S2000 M3
I use M810 to signal a function that parses the tool information and displays it in a tool change windows so the operator can do the manual change:
(http://www.gausstek.com/toolchange3.jpg)
Of couse some users wont be able to make their postprocessor output this information, and also some others use auto tool change.
What tool change behaviors do you think I should include in the screenset tso most users can use it?
If it's intended for any user, then may be leave the same 'behaviour' as with the standard Mach screen set...?
