Mach Discussion => General Mach Discussion => Topic started by: kdoney on October 08, 2006, 07:00:25 AM
Title: RhinoCAM post processor
Post by: kdoney on October 08, 2006, 07:00:25 AM
The RhinoCAM post processor always gives me a G43 in the setup code but the control doesn't understand it (Mach3 1.84.001). Is the post wrong?
Title: Re: RhinoCAM post processor
Post by: Hood on October 08, 2006, 08:47:52 AM
Can you post a sample code, then it could be tested by others. G43 works fine for me.
Post by: kdoney on October 08, 2006, 09:23:23 AM
It is a Mach2 post processor but I thought it still should work.
Post by: Hood on October 08, 2006, 09:42:02 AM
I am a total beginner at G code but I think there should be an H before the offset value, eg line should read G43 H0
Take this with a pinch of salt as I said I am a novice when it comes to code.
Post by: Graham Waterworth on October 08, 2006, 04:28:32 PM
Hood is correct in his reply,  the G43 should be followed by a H value,  do you always get a zero, try telling rhino you are using tool 1 or above and see if that changes the output.
Graham.
Post by: captain_chaos on October 14, 2006, 05:56:59 AM
Hi kdoney,
when i changed from Mach2 to Mach3 i had the same error.
If you edit the g-code with Mach it will work fine again. Only delete the 0 behind G43, that`s all.
I think you can change the Postprocessor settings inside Rhinocam so it will never write the 0 again.
Andy
