G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: woodguy7777 on April 11, 2010, 04:17:17 PM
i have fitted a laser pointer on my cnc so that it makes it easy to centre my bit.
using MDI alt2 i enter this offset g0x-0.3709y7.0013 this brings my router bit to where the laser point was.
what i am trying to do is to put this in a file form.
instead of having to keep typing it in the MDI box.
just bring up the file and hit cycle start
paul
You can add a button that calls a macro to do that
If you only want to go to the laser position the macro can be
Code ("g0x-0.3709y7.0013 ")
If what you want to do is zero the work coordinates in the laser position, you can do it without even moving
SetOEMDRO (800,0.3709)
SetOEMDRO (801,-7.0013)
Regards
Hi Paul,
The system I use is shown on this page http://www.cooperman.talktalk.net/files/17.htm
The scripts for the screen buttons are at the bottom of the page, obviously you need to modify the second one with your offset dimensions.
Hope this helps,
thanks Elpablito and Tweakie.
tweakie, the link you sent was very helpfull.
thanks paul
