Mach Discussion => General Mach Discussion => Topic started by: rrc1962 on April 10, 2010, 05:33:04 PM
Hi all...
On a gantry machine if I have and X and A axis and I use RefCombination(9), will it home the first switch to hit home then the other switch? Or will it always home the X first then the A? If the latter is true, I'm wondering what happens if the A switch hits home first. Seems that it would over-run the A switch a little and home the X, but then with the A switch already activated, how would it then home the A side? I'm considering changing to a two motor system and want to make sure I understand how slaving works.
Thanks very much.
They home at the same time, but independently.
