Mach Discussion => General Mach Discussion => Topic started by: xaco on April 06, 2010, 07:32:49 PM
hi everyone,i have a problem with my fourth axis.....when i write in MDI to rotate it 90 degrees, it makes 90degrees in mach but in practice it makes a move of ..like 98 degrees....... where can i set that in mach3,so taht 360 will make it do exactly the full circle.. ? thanks Miroslav
You need to set your steps per unit correctly in motor tuning for the A axis. For indexing the units would be in steps per degree.
