Mach Discussion => FAQs => Topic started by: Larry1592 on March 16, 2010, 12:08:09 AM
How do I set up a Joystick in Mach 3?
Hi Larry,
There are a number of possible joystick solutions in the 'Plugins section' here http://www.machsupport.com/forum/index.php/board,30.0.html
Just a word of warning:-
Because joysticks and hand-held controllers tend to be used much closer to the machine than the keyboard is normally used extra vigilance is required to ensure your personal safety.
There have been a number of cases reported where the data stream has been unexpectedly interrupted (such as accidentally pulling out the USB plug) and one or more of the machine axis has run away out of control. The lesson here is “take care and don’t get too close” when using these devices.
Thank you very much.
Larry
I'm looking for a Plug-in for a joystick GF G60502A 3 axis 6 button unit. Neither of the items in the list of Plug-ins worked. The basic one by Art Fenerty works for the X & Y but is only a two axis, no button app.
David
