Mach Discussion => FAQs => Topic started by: robh on March 12, 2010, 04:59:35 PM
I have been trying to mill an outside shape and get an undersize finished item. The cutter is cutting on the line even though I have used the outside command during setup. i.e the part is undersize by the diameter of the cutter.
The tool diameter is set in the tools menu so there is a obviously a parameter I am missing. Any help welcome.
Thanks.
What program or wizard are you using to generate the code?
You could tell the program that the cutter is smaller by some amount and thus when you use a cutter larger than what the program offset was based on
your part size would turn out undersized if that is what you are meaning.
Thanks for the reply RICH,
I am generating the G-code in Lazy Cam from a dxf. file and use the Multi Pass wizard by Newfangled solutions for the depth of cut (6 pass).
Rob.
Rob,
All you need to do is create an outside offset in LC. Unenable or delete the original profile and then select the layer with offset , go to the layer tab and define the tooling cut. No need to use another program......
All in the manual .....
Thanks again RICH, I'll start again.
Rob.
