Mach Discussion => General Mach Discussion => Topic started by: bobbya47 on March 12, 2010, 10:39:10 AM
Title: Really odd problem
Post by: bobbya47 on March 12, 2010, 10:39:10 AM
I need to cut a path for inserting an o-ring. It is extremely simple, but my toolpath on the machine computer is not the same as my g-code. I drew it up in Bobcad and generated a g-code. The simulation works correctly. When I load it in mach3 on my office pc it works properly. My pc's are on a network and I load it in mach3 on the machine pc I get a different toolpath. I have regenerated the program and also created a different program and it still does the same thing. I am attaching a dxf that shows the difference.
Title: Re: Really odd problem
Post by: Jeff_Birt on March 12, 2010, 12:23:35 PM
Your IJ mode is set differently on the two computers :)
Post by: bobbya47 on March 12, 2010, 03:53:59 PM
I am not familiar with that. Can you explain?
Post by: Hood on March 12, 2010, 04:06:32 PM
Config menu then General Config page second column about 1/2 way down you will see I J Mode, it can be Abs or Inc, change it to the way it is on your computer that is good.
Post by: bobbya47 on March 12, 2010, 04:23:49 PM
That was it. Thanks
