Mach Discussion => General Mach Discussion => Topic started by: countyside on March 05, 2010, 08:00:36 PM
Title: does mach 3 work with USB?
Post by: countyside on March 05, 2010, 08:00:36 PM
i am starting to develop ideas with a router table an wish to move from serial to USB, is this possable using Mach 3?
Title: Re: does mach 3 work with USB?
Post by: keithmech on March 05, 2010, 08:27:29 PM
smooth stepper
Post by: RayGannon on March 06, 2010, 03:30:11 PM
I've switched from a parallel port to the Smooth Stepper USB adapter and have been very happy. It's working flawlessly with Mach and my Taig mill even on an Acer Aspire One netbook.
Post by: Litus on February 17, 2011, 11:11:59 AM
guys,
I have a driver board with parallel port and I would like to use USB, so:
is possible to use a parallel port adapter for USB connection and then use MACH4, it will work well?
Post by: Tweakie.CNC on February 17, 2011, 11:45:02 AM
guys,
The USB to Parallel port cables are intended for printers and will not work at present with Mach3.
As mentioned previously the smooth stepper will connect a USB port to driver board with 25 way cannon D connector and work with Mach3. I occasionally use the SS (with one machine only) and am very pleased with it.
