Mach Discussion => General Mach Discussion => Topic started by: pavlic28 on March 02, 2010, 02:25:06 PM
Title: GO TO zero
Post by: pavlic28 on March 02, 2010, 02:25:06 PM
       Hi guys!
I am using DSPMC/IP controller with servo motors.It is a milling machine. I have one problem. When I press "GO TO Z" button the machine allways go to this position:
X=0.545
Y=0.351
Z=0.045
Why dont the axis go in to the 0.000 position? ???
Title: Re: GO TO zero
Post by: Hood on March 02, 2010, 03:24:47 PM
Could you be looking at machine coords? The GoToZero button will take you to your work offset zero, so if viewing machine coords you will not see where it is.
Post by: pavlic28 on March 03, 2010, 05:27:33 AM
No, I had already checked that. Are there some other configurations?
Post by: Hood on March 03, 2010, 05:56:00 AM
Not that I know of, sounds like it may be a DSPMC issue. If you command a G0X0Y0Z0 move does it go to zero?
Post by: pavlic28 on March 03, 2010, 07:26:51 AM
When i push the zero button or if I put X0.0 Y0.0 Z0.0 coordinates in to the G code it is always go in to the position that I describe in first post.
Post by: Hood on March 03, 2010, 12:39:49 PM
If you want to attach your xml I can have a look at it to see if I can see anything wrong but I think you will really need to contact the DSPMC people and see if they can suggest anything.
Post by: pavlic28 on March 04, 2010, 01:16:37 PM
This is the dspmc file.
thank you!
Post by: Hood on March 04, 2010, 01:19:45 PM
Afraid that seems to be a blank xml you have attached.
Post by: pavlic28 on March 05, 2010, 12:50:39 AM
I can normally  open it with the Internet explorer 6.0  :)
Post by: Hood on March 05, 2010, 01:14:56 AM
The xml you sent is a blankl.
Post by: Picengraver on March 05, 2010, 05:58:03 AM
Hood,
Try again.  Opens for me with IE.
John Champlain
Post by: Hood on March 05, 2010, 06:35:13 AM
John, yes it opens fine but there are no axis enabled etc.
Post by: Picengraver on March 05, 2010, 06:53:00 AM
Thanks.  Sorry I misunderstood what you meant.
John Champlain
Post by: pavlic28 on March 05, 2010, 02:49:41 PM
Hi!
I fix the problem. ;D I just put the diference in the formulas. Like this f(x)=x-0.45
Thank you guys anyway.
