General CNC Chat => Share Your GCode => Topic started by: hightechkey on March 02, 2010, 07:04:42 AM
Title: NC file for 4 axes machine
Post by: hightechkey on March 02, 2010, 07:04:42 AM
Dear Bro
I want to know which CAM software can generate 4 axes tool path for Mach3. I use Master CAM 9 for 3 axes machining. Can I use Master CAM for 4 axes maching?  Now I try to improve 4th axis rotary table in my Milling machine. So, I want to know the 4axes tool path with rotary table (A) axis.
I also want to get 4 axes tool path NC files that someone did. I hope somebody advice me.
Best regards,
High Tech Key
Title: Re: NC file for 4 axes machine
Post by: Tweakie.CNC on March 02, 2010, 07:50:20 AM
High Tech Key,
I generated this demonstration toolpath from an .stl file with DeskProto.
It is not a very practical model because the stepover is too great, it was just done to show you the toolpath.
Hope this helps.
Post by: pointcloud on March 02, 2010, 11:25:01 AM
I think that MC9 has a 4th in it, or its an add-on...
Remeber that Z0 is the center of the work.
