Mach Discussion => General Mach Discussion => Topic started by: mhickler on February 24, 2010, 01:16:47 PM
Title: How can I reverse the direction of my motors (permanently)?
Post by: mhickler on February 24, 2010, 01:16:47 PM
My computer died and I am setting up Mach 3 from scratch. When I home my motors they go away from the switches. Can I reverse them in setup somewhere? I did it two years ago, but now I forget how.
Title: Re: How can I reverse the direction of my motors (permanently)?
Post by: mhickler on February 24, 2010, 01:17:50 PM
I should have mentioned that I am using the milling application.
Post by: Hood on February 24, 2010, 01:28:29 PM
Config menu, homing and limits then choose to reverse the axis you wish. But if the DROs are working the right way as you jog then it will be the Home Negative option you want to change.
Post by: mhickler on February 24, 2010, 01:37:18 PM
Thanks! Worked like a charm.
