Mach Discussion => General Mach Discussion => Topic started by: Andrey67 on February 21, 2010, 12:39:29 AM
How I can on/off this window by means of SuttlePro2, not to use button Tab? From all list of functions in a plug-in not one does not work for me for this purpose.
Have you tried OEM button 323?
I have not tried OEM button 323. I cannot make it. Please, tell, how it to make!
If probably to add a sreen's.
Andrey.
I have added the button in Mach3. And it works from a mouse. But to operate by means of ShuttlePro this function it is impossible. In what there can be a reason?
Hi Andrey,
You'll need to go into: config/ config plugins/ then clck the yellow shaded area labeled config in the shuttle Pro Plug-in area. Then the shuttle Pro picture should come up with drop down menus, allowing you to configure your shuttle pro.
Just use one of the OEM buttons and put "323" in there and that should do it for you.
Hope this helps-
I so did all. But ShuttlePro does not open the lateral panel. What point of the menu in a plug-in should do it?
Some pics of what you need to do i think
Phil
Thanks, Phil!
ShuttlePro has started to work perfectly!!!
Glad to help ;)
Phil
