Mach Discussion => General Mach Discussion => Topic started by: boblee on September 27, 2006, 06:40:44 AM
Hi I installed Mach on my laptop here at work so I could look at the new screens . I'd like to uninstall now because windows keeps trying to install new hardware it calls mach3 driver . can anyone tell me the procedure for uninstalling it ? I don,t see it listed as an installed program in the add or remove programs window. thanks Bob
Right click on MY COMPUTER select PROPERTIES / DEVICE MANAGER/ find the MACH ENGINE and righ tclick on it and delete.
Something like this anyway.
I tried that and I'm not getting the delete option any other Ideas?
HI, In the device manager look for the "Mach X pulsing Engines" Click on that it will drop down and Give you the Mach3 Driver. Right click on that and select 'uninstall' that should take care of it. Do a reboot and you should be good to go..
Chad
Hi Chad that worked thanks alot Bob
No problem
Chad
