Mach Discussion => General Mach Discussion => Topic started by: chipmassa on January 27, 2010, 02:24:18 PM
Title: reversing coordinate system
Post by: chipmassa on January 27, 2010, 02:24:18 PM
hello all. i have been a machinist since i could stand on a milk crate and run a lathe or mill. i understand the coordinate system perfectly. i just finished a router build and having a little trouble.my y axis and x axis are opposite. i jog either axis and after doing a ref all home, the y, goes negative on the DRO. as does the x axis. my home switches are in the "0" positions. z at max height, the x on the bottom left(a and x axis are slaved, gantry style router), and the y axis bottom. do i need to switch the wires or is there a general config setting i am missing.
thanks all!
Chip
Title: Re: reversing coordinate system
Post by: Hood on January 27, 2010, 02:28:59 PM
Config menu then Homing and limits and reverse.
Post by: chipmassa on January 27, 2010, 02:34:25 PM
about 18 seconds after i posted the thread i realised that was it. thanks so much! problem solved!!
thanks hood for the quick reply!!
Post by: Hood on January 27, 2010, 02:38:50 PM
No problem :)
