Mach Discussion => General Mach Discussion => Topic started by: NormB on January 25, 2010, 04:51:15 AM
Title: Remember Settings
Post by: NormB on January 25, 2010, 04:51:15 AM
Is there a way to have Mach3 not reset to 9 9 9 each time you load a G-Code file?  The X Y is not so much a problem but with the same tool it would be nice once Zero is established with a tool unless you change the tool it would be nice to have Mach remember the last setting for Z.
There might be a reason for the reset but with what I have been doing it wold help a lot saving time in resetting Z each time you load a new job using the same tool.
Norm
Title: Re: Remember Settings
Post by: Hood on January 25, 2010, 05:54:57 AM
Not really sure what you are asking but it could either be tool table you need to set up if you are calling a tool or if its just the G54 offset you are wishing to keep then General Config page and choose  persistent Offsets also look at persistent DROs, and Persistent Tools
Post by: NormB on January 25, 2010, 07:04:28 AM
Actually, I am r3eferencing the Z height mostly.  Let's say my z at finish is 1.00 hight when I load a new program then Z is reset to ) not 1" Is there a way to haveMJach not change that settingwhen I load a new program?
Post by: bowber on January 25, 2010, 07:15:29 AM
I don't think mine alters at all when I load a file so it must be possible.
In fact I know it doesn't as I sometimes setup and then move the tool, load a file and it's still got the same zero position so it doesn't alter any of the dro's.
Are you sure there isn't something in you gcode that's telling mach to reset?
Steve
Post by: NormB on January 25, 2010, 07:17:54 AM
Let me look at that never gave that a thought.  I am generating the code with Vcarve so I guess it's possible.
Post by: NormB on January 25, 2010, 07:21:28 AM
thank you got the answer, Yes the Gcode is where this is happening.  I am using tool change ATC for the G-code and that will cause a reset and I nowknow why.
Thanks again.
Norm
Post by: ger21 on January 25, 2010, 05:49:02 PM
It's probably the G43 tool length offset. I edited my post processors to not use it.
