Mach Discussion => General Mach Discussion => Topic started by: rceebuilder on September 21, 2006, 06:39:34 PM
Sometimes I use loop function to pocket rubber label moulds . Usually there are 50 copy of the mould on a A4 size magnesium plate . With this way the toolpath program can be kept smaller. I use this function because with the 10 mb of toolpath program mach3 gives watchdog alarm. But loop function is not user friendly.Let's say I write there 5 then I confirm with the enter then start the cycle but if I pause or stop the cycle for any reason it turns again to 0 . I don't know it is a bug or not.
Rceebuilder
rceebuilder.
Did you resolve the problem? I noticed there were no replies posted.
Sorry I can't help you, but I've kept coming back to the picture you posted and looking and thinking 'how has he got the corners so sharp on those pockets?' If there's 50 on an a4 sheet, that makes them tiny.
'fess up please. How is it done?
Jim.
Is this still a problem in the latest version? If so we will have a look at it :)
Brian
