Mach Discussion => General Mach Discussion => Topic started by: raccawasaki on January 18, 2010, 01:54:20 PM
Title: Wiring FL60STH86-3008B 8 wired stepmotor HELP!!!
Post by: raccawasaki on January 18, 2010, 01:54:20 PM
Hello everybody,
I need help whit wiring a FL60STH86-3008B stepmotor (8 wired)
on a ME742 driver...
I only wanna know which colors need to be in A+ A- B+ B-
i have bleu/bleuwhite red/redwhite green/greenwhite and black/blackwhite
I am a carpenter who can work whit mach3 but now i am building one..and now i have too wire everything   :-\
there is only one question left.. simple explane please..i am not an electrician  ;D
Help me please.... somebody
greetings from holland
Title: Re: Wiring FL60STH86-3008B 8 wired stepmotor HELP!!!
Post by: raccawasaki on January 18, 2010, 01:58:06 PM
I want it bipolar parallel connected
Post by: Hood on January 18, 2010, 03:09:29 PM
This looks like it will be the same as your motor.
http://www.motioncontrolproducts.co.uk/pdf/M60STH88-3008DF.pdf
Post by: raccawasaki on January 19, 2010, 12:16:20 AM
I founfd some info on the internet..but i was still in doubt..
;D yes this answers my question  ;D
Thank you very much Hood :-*
Post by: stirling on January 19, 2010, 08:11:35 AM
Hi guys
I use both these motors and at first sight they appear identical and are supposed to be interchangable. However there is one very annoying and subtle gotcha.
See my post http://www.machsupport.com/forum/index.php/topic,12773.msg83404.html#msg83404 (http://www.machsupport.com/forum/index.php/topic,12773.msg83404.html#msg83404) (reply #5) to see what I mean. The scheme on the left is M60STH88 and on the right is FL60STH86. At first glance they look the same, indeed all the colours line up with the labels A, A dash etc. BUT the start of the coils is on different wires. Parallel wire an FL60STH86 up as per the M60STH88 and it'll be phase fighting and jumping around like a box of frogs. Use the diag on the right for the FL60STH86 motors.
Ian
Post by: raccawasaki on January 19, 2010, 12:44:06 PM
I am still bit confused  ???
there are two options if i understand :
Option 1:
A+ = Bleu/White-Red/White
A-  = Bleu/Red
B+ = Green/White-Black/White
B-  = Green/Black
Option 2:
A+ = Bleu-Bleu/White
A-  = Red-Red/White
B+ = Green-Green/White
B-  = Black-Black/White
Which option do i need for wiring the FL60STH86-3008B to the ME742 bipolar parallel connected?
Greetz,
Ralf
Post by: stirling on January 19, 2010, 01:07:03 PM
Option 1 is correct - option 2 is completely wrong as you'd be connecting both ends of each coil together.
Ian
Post by: raccawasaki on January 19, 2010, 01:14:44 PM
Thanks Ian   ;D
greetz,
Ralf
Post by: Tekno on January 22, 2010, 03:14:06 PM
Hi I tekno
nev design cable connect for FL60STH86
Bipolar Parallel connect
RED + YELLOW-WHITE: A
YELLOW + RED-WHITE: A -
BLACK + GREEN-WHITE: B
GREEN + BLACK-WHITE: B -
