Mach Discussion => General Mach Discussion => Topic started by: jefftouch77 on January 12, 2010, 11:37:27 PM
Hi guys,
just wanna ask some help to you guys,cause hard time with my scanner...
I'm using a "MACH2 CNC CONTROL PROGRAM" to run and control my scanner.
But in some reasons my scanner now is not functioning,i try to diagnose the problem
but theres no problem with my scanner.when i check my systems properties of my PC
under device manager,my MACH2 Driver has a ? on it...
Guys can you help me where i can get the driver for my program....Please some help please.. :(
Its a long time since I have used Mach2 but the procedure should be the same as for Mach3.
To install the driver you can go to device manager and delete the one thats there then go to the Mach2 folder and run the drivertest,exe that should re-install your driver.
If I recall the driver test in Mach 2 is called OCXDriverTest.exe
