Mach Discussion => General Mach Discussion => Topic started by: j king on January 11, 2010, 05:51:58 PM
I cant seem to get any code when I enter infro on the engraving wizzard. Any manual for this? Thanks Jim
Hi Jim,
Make sure you have a FONT selected and then hit the WRITE key.
HTH,
Russ
I never hit" WRITE" Russ.. that worked thanks!
No prob Jim.
Don't think there is a tutorial, the rest of it is pretty straightforward.
Good luck,
Russ
You may want try a serach and see what you find. I don't know of any specific manual and only
tried it a long time ago. You just select the font,input where you want to start along with feed rate,
pick the direction of how the text will be placed, input the size and cutting depth, type something, click the wirte
button, return to mach a there is the code for what you typed. Can only do a single line of text though.
