Mach Discussion => General Mach Discussion => Topic started by: jd1uth on January 07, 2010, 04:04:48 PM
Hallo
i have a cnc4pc multifuncion cnc board C11 can some whane tel me wat i have to use for driver to de steppers I use the t x-y As Japan Servo KH56QM2-951
Z As 23LM-co77-02v what is the best option to use i think this wil be ok driver MSD-32-2.5?
GR Jan
No one hoe have a answer for me wat is the best combination for the c11 board
You need Stepper drivers?
Look at Gecko's.
http://www.geckodrive.com/
Maybe give a link to the drives you mentioned as most probably dont know what MSD-32-2.5 are, so hard to say if they will do.
Ok this drive MSD-32V-8 i mean or wil dis to be ligcht
http://www.stappenmotor.nl/Datasheets/microstapdrivers%20info/MSD-32V-8.htm
or this whane
http://www.stappenmotor.nl/Datasheets/microstapdrivers%20info/MSD-50-5.6.htm
link steppers http://www.mechapro.de/motor-e.html
The first one should work ok but its borderline on current and I would tend to go for the bigger one if it was me.
