Mach Discussion => Mach Screens => Machscreen Screen Designer => Topic started by: M250cnc on December 27, 2009, 07:04:03 AM
Hi Klaus,
In the top right hand corner is the box displaying the properties.
Would it be possible to add the two figures together so that a dro displays LEFT EDGE + WIDTH & TOP EDGE + HEIGHT
This would then make a total of 6 dro's
Reasoning i position my box at the required top and left edges but i want the box to finish at the screen edge
Maybe it could be that you could fill in the right edge and this would calculate the width etc
Phil
Hi Phil,
I implemented your suggestion in version V1.35 which can be downloaded from my site. When you change left, right, top or bottom parameter, the width / height is calculated. If width or height is < 2, the entry is ignored and an error is thrown.
Klaus
Hi Klaus,
You are truly amazing amazing.
Phil
