Mach Discussion => FAQs => Topic started by: Roadkill_321 on December 24, 2009, 01:07:37 AM
Hi, I have been having intermittent errors when I run GCode files. Right at the start where Mach is given an M3 command, I sometimes get a popup that says Error in Line (Line number) - Unspecified Failure and the program stops. If I then hit cycle start again the program continues, but does not start the spindle. It doesn't do it all the time, but when it does it I have to restart Mach3, then the problem usually goes away. Has anyone else had this problem?
I am using version R2.61 of Mach3.
John
I have since figured out that the error occurs not when the program sends an M3, but when it sends a G20.
Mach then says "Error in Line 2 - Unspecified failure", Line 2 being where the G20 is.
It is very annoying >:( and I would like to resolve this if I can. Any suggestions?
Thanks John
