Mach Discussion => General Mach Discussion => Topic started by: giannis121 on December 08, 2009, 07:15:24 AM
Title: Image LED on Mach3Screen.
Post by: giannis121 on December 08, 2009, 07:15:24 AM
When using "screen4", we can use bitmap LEDs by showing the bitmap path to the properties of the LED.
Where is that setting in Mach3Screen? I can't locate it...
Giannis
Title: Re: Image LED on Mach3Screen.
Post by: Joseph on December 08, 2009, 11:36:59 AM
I think you can double click on "None" for image path to allow a different bitmap.
Post by: giannis121 on December 09, 2009, 12:59:50 AM
Very good,
but where is that menu hidden?   ???
Post by: Klaus1311 on December 09, 2009, 04:49:29 AM
Hi Giannis
are you using Mach3Screen or MachScreen? If you are using MachScreen you find in the property dialog all the parameters for the selected controls.
Klaus
Post by: giannis121 on December 09, 2009, 04:52:18 AM
I use Mach3Screen.
Where can i download MachScreen?
I can see it in the download page anywhere....  :(
Post by: Klaus1311 on December 09, 2009, 04:55:46 AM
Hi Giannis
you can download it from:
http://www.kd-dietz.de
select english move to project  -> mach3 screendesigner -> download
Post by: giannis121 on December 09, 2009, 05:03:26 AM
Wow. look some things...
I use 2 years now Screen4 and Mach3Screen and i didn't know there is MachScreen.
Why there is no link in the main download page?
Looks quite good...
Thanks for replying...
