Mach Discussion => General Mach Discussion => Topic started by: Tristar500 on November 30, 2009, 04:03:31 PM
I'm looking for a way to edit the code generated by the digitizing wizard (not plug-in) to a more usable format. The file Mach generates is missing the x, y and z characters and simply separates the coordinates with a comma.
I could generate a point cloud in my cad program if the code was simply edited to include the X, Y and Z letters in each line..
Here's an example
Here's what I have to start with from Mach
-6.032136,1.419120,0.835333
-5.907102,1.419120,0.822000
-5.782069,1.419120,0.803333
-5.657035,1.419120,0.776000
This is what it needs to end up as so my cad/cam can read it.
X-6.032136,Y1.419120,Z0.835333
etc..
Any suggestions?
See if this works..
al
Another excellent program Al.
if you go to the Config menu then Ports and Pins then Mill Options then digitizing you will see a box that if checked may put X Y and Z letters in for you
good luke for me is wrok very well
tulip
Hi Out their , Can anyone tell me how to retrieve the probe setup, in Mach3 ! I looked at the tutiral for Mach3 !
opened up ,operator , scroled down to ,VB Script Editor, clicked it and opened up folder in that window , could not find the PROBE listing like in the tutiral for Mach3!! ? ANY Help THANKS
