Mach Discussion => General Mach Discussion => Topic started by: bdmsb on November 25, 2009, 12:25:34 PM
Title: Radius errors with G2 command
Post by: bdmsb on November 25, 2009, 12:25:34 PM
I'm using CamBam to generate G code and Mach3 complains about a G2 command no matter how I define the hole in CamBam. The error message is:
"Radius to end of arc differs from radius to start"
I've tried using a drill operation and a profile operation with the same result. I haven't been able to ask CamBam about it and I'm beginning to wonder if maybe Mach3 has too restrictive settings on G code tolerances that can be lessened. I don't know G code well enough to puzzle out the G2 command. The hole is 1" in diameter cut with a 3/16 end mill:
G2 F20.0 X1.0469 Y1.2635 Z-0.0425 I-0.4063 J0.0
Title: Re: Radius errors with G2 command
Post by: ger21 on November 25, 2009, 12:36:38 PM
Change your IJ mode in General Config.
Post by: bdmsb on November 25, 2009, 01:23:30 PM
That's it! Thanks.....
