Mach Discussion => Mach SDK plugin questions and answers. => Topic started by: barbera on October 29, 2009, 04:24:33 PM
:) Good night ART SOFT . Sorry for the delay.
I think you're right.
The logarithm using with plugin mach3 (Engraving Trigger for Laser) , it's just on and off.
The power supply of direct current CCW,Not able to turn very fast laser tube.
THIS IS THE BIGGEST PROBLEM.
Materials;
CO2 LASER 40w. Chinesse.
SUPLLY POWER 100W. Chinesse.
Many of my tests can watch them on GRANITE BLACK ZIMBAUE,
You can see that there is No grayscale, the only solution is to apply with Adobe Photoshop, the tool
half tone bitmap.
HALFTONE SCREEN,
IMPUT 100 dpi, Output 100,
FREQUENCY : 85
Angle : 45
SHAPE : ELLIPSE .
The photos have a low resolution 100 dpi, speed 4500 mm p / minute, about two hores for a picture of 260mm 260mm.
My question is:
How do you think would be walking mach3 plugin, with a laser pulsed ??
You think with a laser SYNRAD 25 w radio frequency would be allright ?.
IS IMPOSSIBLE HAVE A LASER WITH GRAYSCALE???.
barberax@gmail.com
I'm not quite sure what you are saying, but I have had a problem with the plugin too. I found it easier to just use the lazycam engraving and use the z direction pin to control the laser. I have a 25 watt synrad laser and it works pretty well.
:)hello Ohpakron, have you any photos engraved????.
thanks.
by.
