Mach Discussion => Brains Development => Topic started by: macona on October 28, 2009, 01:50:50 AM
I am using a Pokeys with Hood DRO code to do the spindle override. The brain viewer shows it is outputting 0-150% to Spindle% termination output as I turn the knob but the spindle stays the same speed. Hood is using it with MachMill. Should this work with MachTurn? Is Spindle% screenset dependent?
Same result here. Do you have solved the problem? Anyone know why we get this result? Thank you
Jep i have the same by the mill tomoroww i post the brain
Is someone already managed to solve this problem? ???
I have tried all sorts but do not move DRO74 (spindle%) :(
i have same problem i cannot move dro74 in mach3 turn but it works in the mill
