Mach Discussion => General Mach Discussion => Topic started by: Robhi on October 27, 2009, 04:09:53 PM
Hello,
I try to write in Arabic language in both Mach3 as well as Mastercam , but the letters are always separated in both of mach3 and mastercam... attached one image of mastercam that shows the separated letters, the other image is a Word document that shows the right word that (form) that the word should be..so I can write correctly in word but not in mastercam neither in mach3 itself..
could I have your help please?
Robhi
I believe you are going to have to use a program that allows you to save text as curves. I've done it (not with Arabic) using Corel. You can export the text as curves using an output that your CAM software will recognize, and when opened it sees it as a graphic rather than text. (You may have to 'trace' the outline to get a usable file.)
Hello,
OK, thank you, I will try to do so, and will let you know.
Thanks again
Robhi
