Mach Discussion => General Mach Discussion => Topic started by: Garyv on September 05, 2006, 08:29:07 PM
I am thinking about setting up a second Mini Mill and wondered if there is a place to save and change the configuration of Mach 3 to save all parameters on each machine so if I am running one mill then connect to the second mill is there a fuction to save all info on each machine ?
I just dont want to get a second computer and dont plan on running them both at the same time ..
THanks
That is no problem :) look in the manual about setting up a new profile. you could have a lathe and 3 mill on the same computer :)
Thanks Brian ,
I will check it out
