Third party software and hardware support forums. => Galil => Topic started by: srbliss on October 10, 2009, 12:37:24 AM
Now what? I know I need to get a 100 pin SCSI cable and a break out board. What other 'fun' do I have in store??
Steve
100 pin cable: http://cyberresearchuniversity.net/store/cables-wiring/pc-computer-cables/scsi-cables/CBSCSI_10003_4229.2.htm (http://cyberresearchuniversity.net/store/cables-wiring/pc-computer-cables/scsi-cables/CBSCSI_10003_4229.2.htm)
That's the 3ft. cable. They also have 6 and 9 ft. cables.
100 terminal breakout: http://cyberresearchuniversity.net/store/cables-wiring/terminal-panels-breakout-wiring-termination-blocks/scsi_breakout_panels/TP_DIN100S_1670.2.htm (http://cyberresearchuniversity.net/store/cables-wiring/terminal-panels-breakout-wiring-termination-blocks/scsi_breakout_panels/TP_DIN100S_1670.2.htm)
This is cheaper than going the Galil 2900 ICM route, but you will have to forgo the opto-isolation option and HI/LOW amp enable features that the Galil ICM provides.
Steve
