Mach Discussion => General Mach Discussion => Topic started by: Toad on October 07, 2009, 11:21:21 AM
Hi all;
when I am running a program, or if it is sitting idle, mach-3 e-stop will need resetting. I have it running through the boardon for mach-3 to controol.
Has anyone else ran into this, and how do I fix it. Also, my limit switched do the same thing. If I look at the setup screen everything is clear.
I click on the reset tab, and restart. very anoying.
I also set up my homing in the config. Homing limits, and "Y" and "Z" go th zero machine coordinates , but "X" does nothing. Am I setting it up incorrectly?
Any and all help would be appreciated.
Toad
Sounds like noise issues, try setting the Debounce Interval to 2000 and see if that helps. If it does then best thing is to make sure your limits are properly shielded so that you can then again lower the debounce.
Thanks Hood;
I haven't thought of that, I'll give it a try.
Toad
That worked for the e-stop, thanks
Toad
