G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: LockTech on October 05, 2009, 04:42:16 PM
I am wondering if there is a way in LC to widen a line or do I need to do it in the CAD program? In the past I had always hand written Gcode, but now that some operations are more complex I am learning CAD & CAM. For example I have a 3/16th bit and I need to widen the path .003. Obviously this will require two paths, but what I am really wondering is there a option in LC to accomplish this?
locktech,
You can add a line a distance away from the other in CAD and if they are on the same layer then you can assign the same cutting cutting parameters to them. So consider it as a single machining operation. I just can't remember now without trying, but , I believe you can create an offset of a line, in this case .003" . Then move the offset to the other layer and do as first stated.
Rich, are you talking about the offset feature LC has? I didnt even think about using a offset.
Cool, I think I just did it in LC. I had to create a tool size thats going to be 1/2 the size of my intended offset, this should give me the correct widening of the line, I beieve. I think this will work out good. Thanks for the point in the right direction Rich.
I think there is a some info in the manual, one of the tutorials, about using lines. Just that you need to take what is in the manual info and creatively apply it sometimes. ;)
