General CNC Chat => Share Your GCode => Topic started by: Chris.Botha on September 19, 2009, 10:05:47 PM
Title: Profiling plastic sheet
Post by: Chris.Botha on September 19, 2009, 10:05:47 PM
hey guys..
I am trying to cut stencils on my mill.. i setup a flat area, 400mmx400mm and affix the plastic sheeting to the acrylic table with double sided tape.
everythign works great but i am having nightmares finding cutters and speds that will work ok.
I tried a profile cutter, a pyramid and ever a tapered ballend, all with the same result, a rough melted edge. My spindle cannot go slower than 5K RPM and i cannot chase faster than 780mm/min for now.
the cuts are very shallow, 0.55mm to 0.65mm max so i set it to cut through to about 0.8mm since under the plastic sheeting is just more acrylic anyhow.
I tried "up" cutting and "down" and up yielded better results.
Is anyone else here cutting plastic sheet that can give em a poke in the right directions.
Attaching gcode im trying to cut. The stencil is to be used for spray painting. this is jsut a sample design.
maybe i need to be looking at a drag cutter rather than a cuttintg tool in the spindle?
Title: Re: Profiling plastic sheet
Post by: ostie01 on September 19, 2009, 10:27:50 PM
You could spray a little bit of water with an old windex  bottle, this will help.
If you coldl buy a single flute cutter, this will also help.
Or some withe Petroleum on the endmill with a brush.
Jeff
Post by: Chris.Botha on September 20, 2009, 03:07:59 AM
i tried a profile cutter.. not so good.. but a 3 sided pyramid cutter worked ok. my spindle can only go down to 5000rpm which is what i suspect my problem i here.. i need to go slower or add coolant at the tip.
firebird did not work but the plain daisy thing was ok..
Post by: ostie01 on September 20, 2009, 05:29:14 AM
Maybe this is due to the haircut  ;D ;D ;D ;D ;D ;D ;D
Post by: Overloaded on September 20, 2009, 07:54:12 AM
Chris,
If you can afford the time, cut it in 2 passes. Offset your first cut .005" - .010" or so........then climb cut it to finish.
Might get you by.
Post by: Tweakie.CNC on September 20, 2009, 08:14:14 AM
Chris, Are you using an air jet to your cutter ?. If not then try it and see what happens then.
Post by: Chris.Botha on September 20, 2009, 02:50:02 PM
thansk for the tips guys, i think coolant is the answer, or a different brand/type of plastic sheet. bout this stuff from local $2 shop, its table place mats i think. dirt cheap, $2 for 6 of them, each one is 550mmx400mm
maybe too cheap ;)
Post by: Chris.Botha on September 23, 2009, 03:05:42 AM
ok, i honed a profile cutter even more into a ...  ummm 2.5 sided cutter  ;D ;D ;D
works like a charm.
Wife is happy, painting her bathroom as we speak, and as we all know, a happy wife is a happy life, an unhappy wife is a bucket of strife!
Post by: Tweakie.CNC on September 23, 2009, 04:46:39 AM
I expect to see photos of the completed bathroom with stenciled dragonflies and daises everywhere !.
btw. In the high street are two barbers who are in stiff competition. To increase trade, one put out a sign that said 'Haircut £3.00'. The following day, the other put out a sign that said 'We repair £3.00 Haircuts'. I could give you his address Chris if you fancy a trip to the UK.
Post by: Chris.Botha on September 23, 2009, 04:53:16 AM
mwaaaaaaaaaaaaaaaaaaaaaaahahahahahaahaahahaha
the bathroom is still a WIP!
my hair is fixed tho :)
Post by: Tweakie.CNC on September 23, 2009, 09:20:32 AM
 ;D
Post by: Chris.Botha on September 25, 2009, 11:59:27 PM
wife will murder my butt if she knew I was posting home images here, but here ya go. think she might post on my facebook page,
http://www.facebook.com/home.php#/pages/Melbourne-Australia/Digital-Jeweller/136490863976?ref=nf
in the stencil section too. feel free to join and become a fan!
bolster my numbers!
Post by: ostie01 on September 26, 2009, 03:11:11 AM
I just told your wife, good luck.  ;D ;D ;D ;D ;D
Nice work, as usual.
Jeff
Post by: Tweakie.CNC on September 26, 2009, 09:23:13 AM
Wonderful Chris. I knew it would be.
Post by: Chris.Botha on September 26, 2009, 04:25:11 PM
Thanks Guys!
Post by: Tony Woollacott on January 17, 2012, 03:58:28 AM
hey chris, how about some dxf's? looks like you got some nice ideas!
Post by: stirling on January 17, 2012, 06:46:52 AM
Chris - I've done a bit of "plastic" machining and though I'm no expert my results have been VERY different depending on the type of plastic. For example what I think is called "rolled acrylic" is hopeless - it just melts BUT "cast" acrylic machines a treat. I did get *some* success with "rolled" by slowing the cutter right down and I mean sloooooow just a few revs/sec but still wasn't brilliant.
Ian
