Mach Discussion => General Mach Discussion => Topic started by: tubular2000 on September 18, 2009, 09:46:48 AM
hi all
I'm in the process of shopping for a 3 axis cam software. I did a good evaluation of visual mill and am pleased with it, but then I found sprutcam wich is similarly priced and appear to have the same level of fonctionality.
If someone is using these softwares, I would appreciate your comments, especialy where you found limitations in things that you wanted to do but where limited by the software capacity.
thanks
If you are new to CAM you might have problems learning to use it as I did. The SprutCAM user forum can help you get started but I found that the tutorials offered by Dave (Pearson?) in the UK really helped.
Mike
VisualMill is the best program i have worked with, in terms of surface finish, and i have worked with, ArtCam, DeskProto, Modela, RC, and quite few others not worth mentioning...
I work with its Rhino based variant called RhinoCam, and a great many cad packages out there that feature built in CAM are in fact sporting VisualMill as a plugin.
I am updating to RhinoCam2 in the next week or so and will be doing some free video tutorials for 3 and 4 axis jewellery applications using VM/RC2.
watch this space :)
