Mach Discussion => General Mach Discussion => Topic started by: TylerQSS on September 11, 2009, 05:02:45 PM
Title: New to routing need help with letters
Post by: TylerQSS on September 11, 2009, 05:02:45 PM
I'm very new to routing but have experience running a vinyl cutter.
We've got our router up and running and have cut out a few words using lazycam/mach3
The issue were having is the router is rounding parts of letters that should be a 90 degree corner,  such as the corners on the top of an upper case L.
I'm not sure where to start with this problem if anyone has any suggestions I would greatly appreciate it.
Tyler
Title: Re: New to routing need help with letters
Post by: Sam on September 11, 2009, 06:04:12 PM
Have a read here...  http://www.machsupport.com/docs/Mach3_CVSettings_v2.pdf
Post by: vmax549 on September 13, 2009, 02:22:25 PM
ARE you actuall cutting the letters or just looking at the toolpath generated?
Post by: TylerQSS on September 14, 2009, 09:11:56 AM
cutting the actual letters,  the tool paths all look right with good corners but when cut the corners get rounded.. this is my first day at work since I made the post so I'm gonna try some of the settings sam suggested
