Mach Discussion => General Mach Discussion => Topic started by: Chip on August 31, 2006, 02:49:28 PM
Title: View Screen's Ver.D1.90.081
Post by: Chip on August 31, 2006, 02:49:28 PM
Hi, Art and All
The attached view's show some changes, In normal view mode the spindle is shorter, In Table Display it's bigger.
In two of the  view's you can see that the spindle and Max size of object cut boundary's are out of scale, this is after zooming with mouse center wheel, If you use the shift left mouse it will zoom normal.
Also note that there is one image mirrored by moving image with mouse.
It will go back to normal after double click to restore start view.
Thank's, Chip
Title: Re: View Screen's Ver.D1.90.081
Post by: ART on August 31, 2006, 08:42:46 PM
Hi:
 What are the program extents on the toolpage on this file?
Art
Post by: Chip on September 01, 2006, 09:42:55 AM
Hi, Art
The file I used is Below, its 4 x 3 y 2 z  inch's and a couple more screen shot's.
Thank's Chip
Post by: Chip on September 01, 2006, 11:34:07 AM
Hi, Art
I figured out how I get in to this mode, If I feed-hold then click on the view and use the mouse
wheel to change the size, this is where the view split's up.
At this point I rewind and Ref All Home, Start again Feed-Hold it will repeat as above, this will
also happen in Table View also, note the Big Spindle.
It doesn't seem to happen if I use Stop.
Hope this Helps, Chip
