Mach Discussion => General Mach Discussion => Topic started by: srbliss on September 03, 2009, 03:31:43 PM
In my mill conversion I need +/-10V to run my servo drives. I was going to use the pixie boards that were made for doing this but they are no longer available. What other options do I have?
Steve
Hi Steve,
I haven't used these but might do the job for you.
http://max-mod-shop.com/index.php?option=com_content&view=article&id=47:yapsc10v&catid=17:-yapsc&Itemid=4
CNC zone thread.. http://www.cnczone.com/forums/showthread.php?t=74532&page=3
ATB
Derek
There are a couple of convertors, one from Rutex and another from here http://max-mod-shop.com/index.php?option=com_content&view=article&id=47:yapsc10v&catid=17:-yapsc&Itemid=4
Dont know anything about either and have not heard of anyone using them so you will have to do your own research :(
The other options are the DSPMC http://www.vitalsystem.com/web/motion/dspmc.php and Dynomotion http://dynomotion.com/ , they are external motion controllers which connect to Mach via plugin. The DSPMC seems to have a lot of happy users but not seen much about the Dynomotion
The last option is Galil.
Thanks for the information, I knew about the DSPMC and found the Dynamotion a few days ago. I have lots of servo drives that need 10 volts so I was hoping to find something inexpensive. I will probably go with the DSPMC for my mill as this is not really a bargain bin project. Yesterday I rescued 6 Galil stand alone controllers before the scrap metal guy got to them, unfortunately they are the only ones (DMS-1540) that the plug-in does not support. I also snagged 24 Galil brush type servo amps!
Steve
Looks like this would work also. http://www.ajaxcnc.com/mach_cnc_systems.htm (http://www.ajaxcnc.com/mach_cnc_systems.htm)
Anyone use one of these?
Steve
Steve
That is very new on the market (less than a month) so not likely anyone has one set up yet. Have heard good and bad about Ajax's other stuff but no personal experience so cant give an opinion.
