Mach Discussion => General Mach Discussion => Topic started by: kolias on August 22, 2009, 10:50:47 PM
I made this simple drawing and got the gcode with Lazycam
Is it easy for someone to explain what the I and J means on the code?
I only know what X Y & Z means
Nicolas
Very sorry, I found the answer
Nicolas
Can you please explain what you found? Very often other folks will search old messages when they have a similar question and your findings may be a valuable resource for them.
he probably just clicked the G Code button in Mach.
Right on Hood, this button has tons of info
Nicolas
The Mach3 Turn - Arc Motion write up in Members Docs provides definiton and has examples of arcs in different positions. For the lathe but still basic good info that you can adjust for the mill.
What is Members Docs?
Nicolas
Nicolas
http://www.machsupport.com/forum/index.php/board,78.0.html
Thank you Hood, nice to know about all this docs
Nicolas
