Mach Discussion => Mach Screens => Screen designer tips and tutorials => Topic started by: lefrai on August 19, 2009, 01:25:33 AM
hello, i am lefrai a new member, I want to know how I can copy russian words from an excel list and then copy them in the masch3screen buttons from my screen, i tried but puts me only ?????? (interrogations signs),
regards
lefrai
Hi Lefrai
what program are using to change the text?
Klaus
I use the mach3 screen designer, but I got a list in russian of all the names of the caps buttons, so I just only change the names, with the mach3screen designer, when I want to copy and paste the word in cyrilics, the mach3screen put me ??????, do not acept this kind of fonts with cyrilics caracters.
lefrai
Hi lefrai,
do get the question marks in the screendesigner when you paste the cyrilics, or in Mach3?
Klaus
hi,
the marks apears in the mach3 screen designer, just when I try to paste the word in cyrilics. in the rectangle where you have to write the name of the button.
regards
marcelo
Hi lefrai,
what screendesigner are you using?
Screen3, Screen4, Jetcam Editor, or MachScreen?
Klaus
its the mach3screen
Hi Lefrai,
I'm not sure whether I can help you at all. First I don't know if diffrent character sets like cyrilic are supported by Mach3, second if I could help you, it would only with Machscreen. The following procedure assumes the language setting english.
If you would use MachScreen, create a new screen and add a button. Be sure the button is selected and doubleclick in the line of "text on control" the string "text" (the background color changes to blue) and write your text in cyrilic.
Klaus
ok, thanks by the way, you are very kind
lefrai
Hi Lefrai,
I thought a bit deeper about your problem. Forget what I wrote before, it is nonsens. The best is to build a bitmap with your cyrillic text and put it on the button.
Klaus
ok klaus,
i will make some bitmaps buttons, and paste the cyrilics on it, it´s the best way to finish with this problem.
thanks
lefrai
