Mach Discussion => General Mach Discussion => Topic started by: Renatox_ on August 16, 2009, 02:27:07 PM
hi forum, i am concerned that when you move the mouse when the match3 it is running at high speeds, the driver generates an alarm for high acceleration.
This only happens sometimes but i'm concerned because the mouse stops the frequency of output pulses for a few moments.
The alarm of high accelerations also occurs when change the MDI window while running the program. Also when i installed NOD32.
My parameters are:
step per: 787.4015
velocity max: 2000mm/min
aceleration: 200mm/s^2
Width pulse: 5us
PC: Pentium 4, 512M, 1.6Ghz
what steps can i take? help
regards
Do the optimisation steps detailed on the downloads page, they might help.
thanks i download recomendation and will revise, some other suggestion,,
very thanks.
Don't play with your mouse. I use a "dead dog" laptop ( Pentium 2 , 400 MHZ, 512 ram ) sometimes , which runs Mach fine, but play with the mouse, not a good idea.
thanks, i can now move the mouse and change the screen for example a MDI while run program. The driver no generate alarm, i continue the following steps.
* Continue some configuration of the Windowns XP Optimization.
* reduced Step Per a half.
* reduced the frecuency a 45khz.
* reduced aceleration of 200 a 150 mm/s^2
i will continue tested.
regards.
