Mach Discussion => General Mach Discussion => Topic started by: tantan on August 16, 2009, 02:35:04 AM
Title: oem code for tooloffset number (turn)
Post by: tantan on August 16, 2009, 02:35:04 AM
hi,
if i change my tool with the command M6 t0123, it meas that i use tool 1 with offset 23. i want to display the used offset (in this example 23) on my screen but i cannot find the right OEM code
thanks
Antoine
the Netherlands
Title: Re: oem code for tooloffset number (turn)
Post by: Hood on August 16, 2009, 05:36:20 AM
There isnt one and is one of the things that hopefully will be added in the new revision of MachTurn.
Post by: Hood on August 16, 2009, 07:06:11 AM
Should add of course that if you have a custom M6 Macro for your toolchanger you could have that writing to a User DRO and thus use it for the offsets. How you do that will depend on how your macro is written but with mine I have calls for each tool so its easy enough to do it.
Post by: tantan on August 16, 2009, 11:43:03 AM
ok thanks hood,
good tip. i am gone try that.
antoine
Post by: Hood on August 16, 2009, 02:05:51 PM
Dont spend too long on it, I was talking through the hole in my **** :(
I was thinking I had done it on the lathe but when I looked again I saw I had tried to do it and couldn get it. It is one of the things I have asked Brian for when he gets working on turn so hopefullY soon :)
Post by: tantan on August 17, 2009, 01:32:31 AM
ok hood thanks,
i will wait for mach4
antoine
